Các từ viết tắt tên Hệ Thống xe Hyundai
Già Làng O-H
Bình luận: 0Lượt xem: 4,674
Già Làng O-H
GIÀ LÀNG O-H
Đây là toàn bộ tên viết tắt các hệ thống trên xe Hyundai, tài liệu chính hãng. Mình nghĩ chắc đủ cả, nếu thiếu các Bạn bổ sung nhé.
1 A/C AIR CONDITIONER
2 A/T AUTOMATIC TRANSMISSION
3 A/V AUDIO/VIDEO
4 ABS ANTI-LOCK BRAKE SYSTEM
5 ACC ACC
6 ACU ALARM CONTROL UNIT
7 ADM ASSIST DOOR MODULE
8 AFLS ADAPTIVE FRONT LIGHTING SYSTEM
9 AFLS LED ADAPTIVE FRONT LIGHTING SYSTEM
10 AMS ALTERNATOR MANAGEMENT SYSTEM
11 APS ACCELERATOR POSITION SENSOR
12 APT ANCHOR PRETENSIONER
13 AQS AIR QUALITY SENSOR
14 ASD AMPLITUDE SELECTIVE DAMPER
15 ATF AUTOMATIC TRANSAXLE FLUID
16 ATF AUTOMATIC TRANSMISSION FLUID
17 ATX AUTOMATIC TRANSAXLE
18 AUX JACK AUXILIARY JACK
19 AVN AUDIO/VIDEO/NAVIGATION
20 BAS BRAKE ASSIST SYSTEM
21 BCM BODY CONTROL MODULE
22 BMS BATTERY MANAGEMENT SYSTEM
23 BPS BAROMETRIC PRESSURE SENSOR
24 BPS BOOST PRESSURE SENSOR
25 BPT SEAT BELT ANCHOR BOLT
26 BPT SEAT BELT PRETENSIONER
27 BPT SEAT BELT RETRACTOR PRETENSIONER
28 BS SEAT BELT BUCKLE SWITCH
29 BTS SEAT BELT TENSION SENSOR
30 BUPT SEAT BELT BUCKLE PRETENSIONER
31 CAB CURTAIN AIR BAG
32 CAN CONTROLLER AREA NETWORK
33 CAS CHASSIS ACCELERATION SENSOR
34 CAS CREEP AID SYSTEM
35 CBS CONVENTIONAL BRAKE SYSTEM
36 CCA COLD CRANKING AMPERE
37 CCV CANISTER CLOSE VALVE
38 CKPS CRANKSHAFT POSITION SENSOR
39 CLU CLUSTER
40 CMPS CAMSHAFT POSITION SENSOR
41 CPU CENTRAL PROCESSING UNIT
42 CUBIS CAR UBIQUITOUS SYSTEM
43 CVT CONTINUOUSLY VARIABLE TRANSMISSION
44 CVVT CONTINUOUSLY VARIABLE VALVE TIMING
45 DAB DRIVER AIR BAG
46 DBC SWITCH DOWNHILL BRAKE CONTROL SWITCH
47 DCCV DAMPER CLUTCH CONTROL SOLENOID VALVE
48 DDM DRIVER DOOR MODULE
49 DIS DRIVER INFORMATION SYSTEM
50 DLC DATA LINK CONNECTOR
51 DOHC DOUBLE OVERHEAD CAMSHAFT
52 DRL DAYTIME RUNNING LIGHTS
53 DTC DIAGNOSTIC TROUBLE CODE
54 EBD ELECTRONIC BRAKE-FORCE DISTRIBUTION
55 EC-AT ELECTRONIC CONTROL-AUTOMATIC TRANSAXLE
56 EC-AT ELECTRONIC CONTROL-AUTOMATIC TRANSMISSION
57 ECM ELECTRONIC CHROMIC MIRROR
58 ECM ENGINE CONTROL MODULE
59 ECS ELECTRONIC CONTROL SUSPENSION
60 ECTS ENGINE COOLANT TEMPERATURE SENSOR
61 ECU ELECTRONIC CONTROL UNIT
62 ECU ENGINE CONTROL UNIT
63 ECW ELECTRIC CONTROL WIPER
64 EEPROM ELECTRICALLY ERASABLE PROGRAMMABLE READ-ONLY MEMORY
65 EGR EXHAUST GAS RECIRCULATION
66 EHPS ELECTRO HYDRAULIC POWER STEERING
67 EPB ELECTRIC PARKING BRAKE
68 EPS ELECTRIC POWER STEERING
69 EPS ELECTRONIC POWER STEERING
70 ESC ELECTRONIC STABILITY CONTROL
71 ESCL ELECTRONIC STEERING COLUMN LOCK
72 ESP ELECTRONIC STABILITY PROGRAM
73 ESS EMERGENCY STOP SIGNAL
74 ETACS ELECTRONIC TIME & ALARM CONTROL SYSTEM
75 ETC SYSTEM ELECTRONIC THROTTLE CONTROLSYSTEM
76 ETCS ELECTRONIC TOLL COLLECTION SYSTEM
77 ETS ELECTRONIC THROTTLE SYSTEM
78 FAM FRONT AREA MODULE
79 FBWS FRONT BACK WARNING SENSOR
80 FIS FRONT IMPACT SENSOR
81 FSIS FRONT SIDE IMPACT SENSOR
82 GND GROUND
83 GPS LPI GAS PRESSURE SENSOR
84 GTS LPI GAS TEMPERATURE SENSOR
85 HECU ESP CONTROL MODULE
86 HECU HYDRAULIC & ELECTRIC CONTROL UNIT
87 HEV HYBRID ELECTRIC VEHICLE
88 HIVEC HYUNDAI INTELLIGENT VEHICLE ELECTRONIC CONTROL
89 HLA HYDRAULIC LASH ADJUSTER
90 HO2S HEATED OXYGEN SENSOR
91 IATS INTAKE AIR TEMPERATURE SENSOR
92 ICM INTEGRATED CIRCUIT MODULE
93 IFB INTERFACE BOX
94 IMS INTEGRATED MEMORY SYSTEM
95 IMTV INTAKE MANIFOLD TUNNING VALVE
96 IPM INSTRUMENT PANEL MODULE
97 ISCA IDLE SPEED CONTROL ACTUATOR
98 ISG IDLE STOP & GO
99 KAB KNEE AIRBAG
100 LDC DC/DC CONVERTER
101 LDWS LANE DEPARTURE WARNING SYSTEM
102 LSD LIMITED SLIP DIFFERENTIAL
103 M/T MANUAL TRANSMISSION
104 MAFS MASS AIR FLOW SENSOR
105 MAPS MANIFOLD ABSOLUTE PRESSURE SENSOR
106 MCC MANIFOLD CATALYTIC CONVERTER
107 MDPS MOTOR DRIVING POWER STEERING
108 MFSW MULTI FUNCTION SWITCH
109 MIL MALFUNCTION INDICATOR LAMP
110 MLA MECHANICAL LASH ADJUSTER
111 MTS MOZEN TELEMATICS SYSTEM
112 MTX MANUAL TRANSAXLE
113 OBD ON BOARD DIAGNOSTICS
114 OCV CVVT OIL CONTROL VALVE
115 OCV OIL CONTROL VALVE
116 OPS OIL PRESSURE SWITCH
117 OTS CVVT OIL TEMPERATURE SENSOR
118 OTS OIL TEMPERATURE SENSOR
119 PAB PASSENGER AIR BAG
120 PAS PARKING ASSISTANT SYSTEM
121 PCM POWERTRAIN CONTROL MODULE
122 PCSV PRESSURE CONTROL SOLENOID VALVE
123 PCSV PURGE CONTROL SOLENOID VALVE
124 PCU POWERTRAIN CONTROL UNIT
125 PCV VALVE POSITIVE CRANKCASE VENTILATION VALVE
126 PDM POWER DISTRIBUTION MODULE
127 PGS PARKING GUIDE SYSTEM
128 PNP PARK-NEUTRAL POSITION
129 PODS PASSIVE OCCUPANT DETECTION SYSTEM
130 P-SIS PRESSURE SIDE IMPACT SENSOR
131 PSM POWER SEAT MODULE
132 PSPS POWER STEERING PRESSURE SENSOR
133 PTC HEATER POSITIVE TEMPERATURE COEFFICIENT HEATER
134 PTM POWER TRUNK MODULE
135 PTO POWER TAKE OFF
136 RAM REAR AREA MODULE
137 RCD REAR CAMERA DISPLAY
138 RKE SIGNAL REMOTE KEYLESS ENTRY(RKE) SIGNAL
139 RPAS REAR PARKING ASSISTANT SYSTEM
140 RPS RAIL PRESSURE SENSOR
141 RSE REAR SEAT ENTERTAINMENT SYSTEM
142 SAB SIDE AIRBAG
143 SAS START ADJUST SCREW
144 SCC SMART CRUISE CONTROL
145 SCM STEERING COLUMN MODULE
146 SCSV SHIFT CONTROL SOLENOID VALVE
147 SIS SIDE IMPACT SENSOR
148 SRS SUPPLEMENTAL RESTRAINT SYSTEM
149 SRSCM SRS CONTROL MODULE
150 SRSCM SUPPLEMENTAL RESTRAINT SYSTEM CONTROL MODULE
151 SST SPECIAL SERVICE TOOL
152 STPS SEAT TRACK POSITION SENSOR
153 TCC VALVE TORQUE CONVERTER CONTROL VALVE
154 TCCSV TORQUE CONVERTER CLUTCH SOLENOID VALVE
155 TCI TURBO CHARGER INTERCOOLER
156 TCM TRANSAXLE CONTROL MODULE
157 TCM TRANSMISSION CONTROL MODULE
158 TCS TRACTION CONTROL SYSTEM
159 TPMS TIRE PRESSURE MONITORING SYSTEM
160 TPS THROTTLE POSITION SENSOR
161 UCC UNDERFLOOR CATALYTIC CONVERTER
162 UIP SENSOR ULTRASONIC INSTRUSION PROTECTION SENSOR
163 VCM VALVE VARIABLE CHARGE MOTION VALVE
164 VCMA VARIABLE CHARGE MOTION ACTUATOR
165 VDC VEHICLE DYNAMIC CONTROL
166 VFS VARIABLE FORCE SOLENOID
167 VIN VEHICLE IDENTIFICATION NUMBER
168 VIS VALVE VARIABLE INTAKE SOLENOID VALVE
169 VSM VEHICLE STABILITY MANAGEMENT
170 VSS VEHICLE SPEED SENSOR
171 WCC WARM-UP CATALYTIC CONVERTER
172 WCS WEIGHT CLASSIFICATION SYSTEM
173 WGT WASTE GATE TURBOCHARGER
174 WSS WHEEL SPEED SENSOR
