Engine Name - Engine Size
CB20 - 993cc - 3cyl - 37 kw (Charade)
CB22 - 993cc - 3cyl - 38 kw (Charade)
CB23 - 993cc - 3cyl Carb SOHC 6v - ? kw (Charade)
CB24 - 993cc - 3cyl Carb SOHC 6v - ? kw (Charade)
CB50 - 993cc - 3cyl Carb SOHC 6v Turbo - 60kW (Charade)
CB50/60 - 993cc - 3cyl Carb SOHC 6v Turbo - 50kW (Charade)
CB51/61 - 993cc- 3cyl Carb SOHC 6v Turbo - 50kW (Charade)
CB60 - 993cc - 3cyl Carb SOHC 6v Turbo - ? kw (??)
CB61 - 993cc - 3cyl Carb SOHC 6v Turbo - ? kw (??)
CB70 - 993cc - 3cyl EFI DOHC 12v Turbo - 74 kw (Charade)
CB80 - 993cc - 3cyl EFI DOHC 12v Turbo - 74 kw (Charade)
CB90 - 993cc - 3cyl EFI - ? kw (Charade)
CB100 - 993cc - 3cyl EFI DOHC 12v Turbo - 78 kw (??)
CL10/11 - 993cc - 3cyl Diesel SOHC 6v - 28kw (??)
CL60/61 - 993cc - 3cyl Diesel SOHC 6v Turbo - 37kw (??)
DL - 2765cc - Diesel SOHC Turbo - 85kw (Rugger)
EB - 547cc - 3Cyl Carb SOHC 6v Turbo - 38 kw (Mira. Cuore. Leeza)
ED10 - 850cc - 3Cyl - ? kw (??)
EF-CL - 659cc - 3cyl Carb SOHC 6v - 29kw (Mira)
EF-DET - 659cc - 3cyl EFI SOHC 12v Turbo - 47kw (Naked, Terios Kid, Terios Lucia, Move, Max, Atrai, Opti, Mira Gino)
EF-DEM - 659cc - 3cyl EFI SOHC 12v Turbo - 44kw (Terios Kid, Terios Lucia)
EF-EL - 659cc - 3cyl EFI SOHC 12v - 40kw (Opti, Mira Moderno, Mira)
EF-FL - 659cc - 3cyl EFI SOHC - 40kw (Mira Moderno, Mira)
EF-GL - 659cc - 3cyl Carb DOHC 12v - 38kw (Move, Mira Moderno)
EF-HL - 659cc - 3cyl Carb SOHC 12v - 37kw (Mira)
EF-JL - 659cc - 3cyl EFI SOHC 12v Turbo - 47kw (Mira TR-XX, Leeza)
EF-KL - 659cc - 3cyl EFI SOHC - 31kw (Opti. Mira Moderno)
EF-RL - 659cc - 3cyl EFI DOHC 12v Turbo - 47kw (Move, Mira TR-XX, Mira)
EF-SE - 659cc - 3cyl EFI SOHC 6v - 35kw (Opti, Mira, Midget 2)
EF-VE - 659cc - 3cyl EFI DOHC 12v - 42kw (Naked, Move, Max, Atrai, Opti, Mira Gino, Mira)
EF-VE2 - 659cc - 3cyl EFI DOHC 12v - 38kw (Mira)
EF-XL - 659cc - 3cyl Carb SOHC Turbo - 45kw (Mira TR-XX)
EF-ZL - 659cc - 3cyl EFI DOHC 12v - 40kw (Move,Opti, Mira Moderno, Mira)
EJ-DE 989cc - 3cyl - 41kw (Cuore L701, Sirion M100)
EJ-VE - 989cc - 3Cyl EFI DOHC 12v - 47kw (YRV)
HC-E - 1295cc - 4cyl EFI SOHC 16v - 67kw (??)
HC-EJ - 1295cc - 4cyl EFI SOHC 16v - 68kw (Terios)
HD-E - 1589cc - 4cyl EFI SOHC 16v - 88kw (Rocky)
HD-EG - 1589cc - 4cyl EFI SOHC 16v - 92kw (Pyzar)
HD-EP - 1589cc - 4cyl EFI SOHC 16v - 85kw (Pyzar)
HD-F - 1589cc - 4cyl EFI SOHC 16v - 71kw (??)
HE-EG - 1498cc - 4cyl EFI SOHC 16v - 74kw (Pyzar)
JB-DET - 659cc - 4cyl EFI DOHC 16v Turbo - 47kw (Copen, Move, Max, Opti)
JB-EL - 659cc - 4cyl EFI DOHC 16v - 43kw (Mira Moderno. Mira)
JB-JL - 659cc - 4cyl EFI DOHC 16v Turbo - 47kw (Move, Mira TR-XX)
K3-VE - 1298cc - 4cyl EFI DOHC 16v - 64kw (YRV, Extol, Copen, Terios)
K3-VE2 - 1298cc - 4cyl EFI DOHC 16v - 75kw (Sirion/Boon M101)
K3-VET - 1298cc - 4cyl EFI DOHC 16v Turbo - 95kw (YRV, Terios)
3S-FE - 1998cc - 4cyl EFI DOHC 16v - 96kw (Delta Wagon)
3C-TE - 2184cc - 4cyl Diesel SOHC Tubro - 94kw (Delta Wagon)
3C-T - 2184cc - 4cyl Diesel SOHC Turbo- 70kw (Delta Wagon)
3SZ-VE - 1495cc - (Materia/Coo M402, Terios J201, Sirion/Boon 1.5 M302) 77kw within the Terios all other 76kw
1K3-FE - 998cc - (Sirion/Boon M300, Cuore L276) 51kw
