AllData 10.40 Full Complect on 39xDVD (2011/1q)
V
Bình luận: 14Lượt xem: 6,945
vinamech
2011/1q | EN | Win All | 39xDVD9 | iSO | 258 GB
AllData 10.40 professional workshop service and repair manual, maintenance, wiring diagram, diagnostic, all cars & light trucks 1982-2011. AllData 10.40 Professional, the leading computer-based diagnostic, repair and estimating information system, can help you boost shop performance and build customer loyalty as you efficiently repair more makes and reduce comebacks.
Alldata contains a full description of repair and maintenance for cars of American manufacture, as well as Asian and European vehicle production produced for the American market. Alldata 10.40 will help to repair not only American cars, but it will renovate and European and Asian foreign cars, since many nodes in the cars are identical, despite the assembly for different markets. The program provides detailed information on repair, which describes the features of the device separate mechanisms, norms of various parameters (volumes of refueling capacities, wheel alignment, etc.), the diagnostic and repair equipment and special tools, the description of works on assembly, disassembly, adjustment, repair and diagnostics, information about the location of components and tools, etc.
The program Alldata 10.40, you can not only repair but also to engage in troubleshooting electronic components car. To do this, you have the following information: location of the diagnostic connector, detailed tables decoding fault codes indicating the possible causes, symptoms, and the consistency checks to fix the problem, description of the read blocks of current parameters with an indication of normative values, work with channel adaptation, etc . This version is the portable version and can be run from an external hard drive, unlike the previous version of this Alldata 10.40 added more drives, now the total number of 39 disk.
AllData 10.40
� The most comprehensive information for 1982 to present vehicles, updated quarterly
� OEM images, diagrams and diagnostic flow charts
� Parts and labor information
� Maintenance schedules
� Manufacturer TSBs and Recalls
� Integrated estimating software
� OEM wiring diagrams with connector, ground, power distribution and splice information
� A2Z Component Search - the fastest route available to component information
Automotive repair shops that use the ALLDATA 10.40 system have a clear differentiation from other repair facilities. ALLDATA-equipped shops can provide their customers with the most accurate repair estimates and proof of diagnostic and repair procedures. ALLDATA also includes factory-correct maintenance schedules that itemize additionally needed services. Moreover, ALLDATA helps shops build consumer confidence and loyalty.
AllData 10.40 Contents List:
Daignosis and Repair
All Diagnostic Trouble Codes(DTC)
Relays and Modules
Sensors and Switches
Maintenance
Engine, Cooling and Exhaust
Powertrain Management
Transmission and Drivetrain
Brakes and Traction Control
Starting and Charging
Power and Ground Distribution
Steering and Suspension
Heating and Air Conditioning
Restraint Systems
Accessories and Optional Equipment
Body and Frame
Cruise Control
Instrument Panel, Gauses and Warning Indicators
Lighting and Horns
Windows and Glass
Wiper and Washer Systems
Parts and Labour
Popular Information
Diagnostic Trouble Codes DTC
Technical Service Bulletins
Specifications
Locations
Diagrams
Service Precautions
Technician Safety Information
Vehicle Damage Warnings
Vehicle Identification
Tools and Equipment
System Diagnosis
Five-Step Troubleshooting
Troubleshooting Precautions
Troubleshooting Tests
General Troubleshooting
Power Relay Test
AllData 10.40 Models List:
- USA (Domestic)
- Asian (Import 1-14) + Model's 1960-1980 (Emission 2002)
- Europe (Import 15-28)
Full list of models available on each disc (total 39 disc's) look in the archives AllData.10.40_0.39xDVD_How.to.Install_Run.From.HD_Manual_Info.List.rar and/or in the basically archive AllData.10.40_0.Install_Disk_2011.I.rar. These archives are on each file-exchanger in the section Download.
Install notes:
- Place all ISO-image files and unpack the archive AllData.10.40_0.Install_Disk_2011.I.rar in one folder on your hard drive (eg.: AllData.10.40);
- Before you install (Normal or Portable), carefully examine the installation instructions! All the detailed instructions found in the archives AllData.10.40_0.39xDVD_How.to.Install_Run.From.HD_Manual_Info.List.rar and/or AllData.10.40_0.Install_Disk_2011.I.rar.
1. Burn or mount the Image "Aldata_10.40.iso" with your favorite Tool.
2. Start Setup and install.
3. After installation is complete, copy the files from Crack-folder in a folder with a installed program's.
4. Enjoy!
*** If a crash bug # 4002, then needed Patch 4002.exe he is in an archive Support_Utilities with the Install disk.
Additional Information:
Portable configuration for database ALLDATA v.10.40, requires no installation.
Run, go to Data-> Devices - and connects the desired disc.
Program Name: AllData 10.40
Program Type: DataBase
Release: 2011
Update (Actual.): 2011 (1st quarter)
Developer: Alldata
Interface Language: EN (USA)
Platform/OS: Win All (32/64-bit)
Crack/SN: Present (Manual & crack)
File Format: iSO (39xDVD9)
File Size: ~258 GB
Homepage: Code: http://www.alldata.com/
Screenshots:
Download:
Code: http://letitbit.net/page/folder/626081|AllData_10.40
http://www.filesonic.com/file/1303566024/AllData.10.40_2011_FS.LINKs.txt
http://www.filefactory.com/f/a86e379945c05668/
http://hotfile.com/dl/122111754/638fca3/AllData.10.40_2011_HF.LINKs.txt.html
As Alt., Download Folders: Code: http://www.filesonic.com/folder/7011571
http://hotfile.com/list/1791016/a9abbde
Upload24.net: Code: http://upload24.net/zba.5acc3fa95a6089955aa82680/AllData.10.0_Portable.rar.html
http://upload24.net/z1f6.cd09571ebfe0dc62692a93d0/AllData.10.40_0.Install_Disk_2011.I.rar.html
http://upload24.net/z1e5.fde510c818dd12be657bb782/DM1Q111.iso.html
http://upload24.net/z8b.2afad685b3b9400f9e046cff/DM2Q111.iso.html
http://upload24.net/z86.3d6db197a8d5f7576312936f/DM3Q111.iso.html
http://upload24.net/z194.17ce50ff840ec934dd0697dd/DM4Q111.iso.html
http://upload24.net/z1f4.ca77d7cb05c4baf8044f39e2/DM5Q111.iso.html
http://upload24.net/z158.a0e4b1ef5feb53c05b568de1/DM6Q111.iso.html
http://upload24.net/z121.b8286c7828a8671b7028e38e/DM7Q111.iso.html
http://upload24.net/z3c.8c59f21a4fb775ce19f664cd/DM8Q111.iso.html
http://upload24.net/z114.3499f1681066377d1fc4c4dc/DM9Q111.iso.html
http://upload24.net/z8d.9d565c0e6ca63622ea8597b6/EMI2002.iso.html
http://upload24.net/z90.f8d47cc1301e9490f0796ce8/IMP1Q111.iso.html
http://upload24.net/z7f.39dd46f2622ec8dadae804db/IMP2Q111.iso.html
http://upload24.net/z13a.798fac456346ca9303d21bce/IMP3Q111.iso.html
http://upload24.net/z17c.c277d80aa5cc934a18704d98/IMP4Q111.iso.html
http://upload24.net/zc9.578e744d40072ef392bee10a/IMP5Q111.iso.html
http://upload24.net/z18f.0e710dbf7075963d8173380f/IMP6Q111.iso.html
http://upload24.net/z8f.0cb39f41e3ef562eab5e811e/IMP7Q111.iso.html
http://upload24.net/z102.d2b1147b3a54cc7018647b64/IMP8Q111.iso.html
http://upload24.net/z167.8bd639f7c3e6501eb4217789/IMP9Q111.iso.html
http://upload24.net/zf6.c0458b4c531d05d6231c15ed/IMP10Q111.iso.html
http://upload24.net/z1f4.ff147bb5062f54c2fba04522/IMP11Q111.iso.html
http://upload24.net/z1d0.c87456bc67e553efcb2d53b3/IMP12Q111.iso.html
http://upload24.net/z106.040e0f3117c85cd62b38c2f9/IMP13Q111.iso.html
http://upload24.net/zc1.d5ee8b98c4b60c7415b987c3/IMP14Q111.iso.html
http://upload24.net/z185.2401cb5d397366b77f959549/IMP15Q111.iso.html
http://upload24.net/z87.20d9c39c0c229fb7dd6eb5c7/IMP16Q111.iso.html
http://upload24.net/z17a.b70f4f322491d2f835a50097/IMP17Q111.iso.html
http://upload24.net/z1d3.5f983e750a26a18cc66e1533/IMP18Q111.iso.html
http://upload24.net/zb8.453a43828a6f6947d72a13e1/IMP19Q111.iso.html
http://upload24.net/z17a.8387672c3cfdb6e03a461681/IMP20Q111.iso.html
http://upload24.net/z1c9.bedee596fb69cfefda8942bb/IMP21Q111.iso.html
http://upload24.net/z4e.9d19c08374249bc11cbbbb82/IMP22Q111.iso.html
http://upload24.net/zdf.c146249c8650188129687efe/IMP23Q111.iso.html
http://upload24.net/z1d6.b59d069522dc8fb1c3e03c95/IMP24Q111.iso.html
http://upload24.net/z1f1.bcc204dcaa42b6a7f74ef487/IMP25Q111.iso.html
http://upload24.net/z163.263468893aba21cec3981aa4/IMP26Q111.iso.html
http://upload24.net/zd0.36c6c6985ccfc324613f7c29/IMP27Q111.iso.html
http://upload24.net/z176.ee0a5b22ad609727456f2db1/IMP28Q111.iso.html
IMPORTANT! - If any of the direct-links will be removed (dead) or if you need more file-service - see the next folder: Code: http://depositfiles.com/folders/I2ZTC6DMG
xedap-4banh
uh, download 258g nếu có tài khoản premium thì cũng mất hơn 1 tháng mới xong. tiền mua account premium + tiền điện + tiền net + công ngồi download chi bằng mua di cho xong. mình đang có phần mềm này, bác nào có nhu cầu thì liên hệ số DT: 090856595.
mình ở nga tư ga, cũng gần ĐHCN, ai có nhu cầu thì liên hệ nha.
N
nguyendangvb
Khách
Bác nào ở Hải Phòng liên hệ với tui theo số điện thoại 0904385835 để có trọn bộ Alldata
nhatvanhva
Bác nào có bộ này ở Hà Nội không nhỉ? và nhiều bộ khác nữa...:8: Mình muốn đến thăm nhà. Mình sẽ mang theo HDD mobile. Thanks.
thigia
bác nào ở cầu giấy - hà nội cần mua ALLDATA AUTO V10.40 258G thì liên hệ 01689960867. giá dao động từ 500 - 700k. có cao quá không?
