The following circuit shows a typical schematic of the 1998 Honda CBR900RR Lights, Switches, and Meters Circuit Diagram.
This includes electrical parts and components such as: headlight, position light, turn signal, license light, tail/brake light, combination meter, speedometer/speed sensor, tachometer, coolant temperature gauge/sensor, cooling fan motor switch, oil pressure switch, handlebar switches, brake light switch, clutch switch, neutral switch, side stand switch, horn and turn signal relay.
Wiring Color Code:
O – Orange
LB – Light Blue
Bl – Black
Br – Brown
Y – Yellow
Bu – Blue
G – Green
R – Red
W – White
LG – Light Green
P – Pink
Legend:
1. Oil pressure light (1.1W)
2. High beam indicator (1.1W)
3. Neutral indicator (1.1W)
4. Left turn signal indicator (1.1W)
5. Right turn signal indicator (1.1W)
Wiring Color Code:
O – Orange
LB – Light Blue
Bl – Black
Br – Brown
Y – Yellow
Bu – Blue
G – Green
R – Red
W – White
LG – Light Green
P – Pink
Legend:
