1989 - 1993 Mitsubishi Galant Chassis and Mechanical Service Manual
V
Bình luận: 0Lượt xem: 1,516
vothanhtam19
This Service Manual has been prepared with the latest service information available at the time of publication. It is subdivided into various group categories and each section contains diagnostic, disassembly, repair, and installation procedures along with complete specifications and tightening references. Use of this manual will aid in properly performing any servicing necessary to maintain or restore the high levels of performance and reliability designed into these outstanding vehicles. Group Index: General, Engine, Fuel, Cooling, Intake and Exhaust, Emission Control, Clutch, Manual transaxle, Automatic Transaxle, Propeller Shaft, Front Axle, Rear Axle, Wheel and Tire, Power Plant Mount, Front Suspension, Active-Electronic Suspension, Service Brakes, Parking Brakes, Alphabetical Index.
How to use this manual, lubrication and maintenance, maintenance service, scheduled maintenance table, vehicle identification. Camshaft and Camshaft Oil Seals, Cylinder head gasket, Engine assembly, Service Adjustment Procedures, Compression pressure checke, special tools, Timing Belt, Troubleshooting guide, Engine mechanical, exploded view and part list. Air Compressor, Air Tube, Indicator Assembly, Lower arm, Shock Absorber Assembly. Here’s a complete service manual document available to download in pdf format consist of 1273 pages.
