[0000004] OBD-II Diagnostic Trouble Codes
khoadongluc
Bình luận: 1Lượt xem: 1,658
khoadongluc
Nothing Is Impossible
Manufacturer Codes:
DTC 01 General Sensor Fault
DTC 02 Instantaneous Battery Voltage Out of Range
DTC 03 Filtered Battery Voltage Out of Range
DTC 04 Compressor Relay Short to Ground/Open
DTC 05 Compressor Relay Short to Battery
DTC 06 Exhaust Valve Short to Ground/Open Circuit
DTC 07 Exhaust Valve Short to Battery
DTC 08 Warning Lamp Short to Ground/Open Circuit
DTC 09 Warning Lamp Short to Battery
DTC 10 Inside Air Temperature Sensor Voltage Low
DTC 10 Intake Accumulator Fault
DTC 11 Driver Seat Forward/Backward Motor Inop
DTC 11 Exhaust Accumulator Fault
DTC 11 Inside Air Temperature Sensor Open Circuit
DTC 11 Transponder Key Problem
